    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Pavilion Gaming Laptop - 17-cd1008tx Product Specifications
16G28PA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
8 GB DDR4-2933 SDRAM (1 x 8 GB)
Video graphics
  • Intel® UHD Graphics
  • Discrete
  • NVIDIA® GeForce® GTX 1650 Ti (4 GB GDDR6 dedicated)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
17.3" diagonal FHD, 144 Hz, IPS, anti-glare, WLED-backlit, 300 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
40.5 x 28.2 x 2.5 cm
Starting at 2.75 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion polymer
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers; HP Audio Boost 1.0
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; OMEN Command Center; HP Connection Optimizer; HP PC Hardware Diagnostics Windows
Pre-installed software
ExpressVPN (30 day free trial); iQiyi; LastPass password manager (30 day free trial)
