HP Laptop - 15s-eq1001au Product Specifications
2D594PA
AMD Athlon™ Gold 3150U (2.4 GHz base clock, up to 3.3 GHz max boost clock, 1 MB L2 cache, 2 cores)
AMD Integrated SoC
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ M.2 SSD
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Windows 10 Home Single Language 64 Plus
HP Connection Optimizer; HP Audio Switch; HP Support Assistant; HP Documentation; HP e-Service; HP JumpStart
