HP ENVY x360 Laptop - 13-ay0055cl Product Specifications
1W891UA
AMD Ryzen™ 7 4700U (2.0 GHz base clock, up to 4.2 GHz max boost clock, 4 MB L2 cache, 8 cores)
8 GB DDR4-3200 SDRAM (onboard)
Video graphics
  • AMD Radeon™ Graphics
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with Corning® Gorilla® Glass NBT™, 300 nits, 72% NTSC (1920 x 1080)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.64 cm
1.32 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion
HP Wide Vision HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP Command Center; HP JumpStart; HP QuickDrop; HP Support Assistant
Pre-installed software
Netflix; Biometric Fingerprint Reader
