9VT71UA
HP ENVY Laptop - 13-ba0010ca
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
8 GB DDR4-3200 SDRAM (onboard)
Video graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, edge-to-edge glass and HP Sure View integrated privacy screen, 1000 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.69 cm
1.3 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion
Battery life mixed usage
Up to 17 hours and 30 minutes
Video Playback Battery life
Up to 15 hours and 30 minutes
HP Wide Vision HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY Laptop - 13-ba0010ca Product Specifications
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Alexa; Biometric Fingerprint Reader; Netflix
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
