HP Spectre x360 Laptop - 15-eb0037tx Product Specifications
15G48PA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
16 GB DDR4-2933 SDRAM (onboard)
1 TB PCIe® NVMe™ TLC M.2 SSD
15.6" diagonal 4K UHD, IPS, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% sRGB (3840 x 2160)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 HDMI 2.0b; 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 AC smart pin; 1 headphone/microphone combo
35.99 x 22.64 x 1.99 cm
Starting at 1.92 kg
135 W Smart AC power adapter
6-cell, 72.9 Wh Li-ion polymer
HP TrueVision HD IR camera with integrated dual array digital microphone
Audio by Bang & Olufsen, quad speakers, HP Audio Boost 2.0
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; ExpressVPN (30 day free trial); iQiyi; LastPass password manager (30 day free trial); Xiaowei
