HP Laptop - 15s-eq1031ur Product Specifications
153N6EA
AMD Athlon™ Silver 3050U (2.3 GHz base clock, up to 3.2 GHz max boost clock, 1 MB L2 cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ Graphics
128 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal HD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
FreeDOS
