    Are you working from home?
    Fix Windows 10 Update Issues
HP Laptop - 15-dw2076nia Product Specifications
9YW08EA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 SDRAM (2 x 4 GB)
Video graphics
Intel® Iris® Plus Graphics
1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal HD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.75 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 6 hours and 15 minutes
Video Playback Battery life
Up to 7 hours
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Pre-installed software
ExpressVPN (30 day free trial)
