    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-da2021nm Product Specifications
7WE62EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
NVIDIA® GeForce® MX130 (4 GB GDDR5 dedicated)
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
37.6 x 24.6 x 2.25 cm
Starting at 1.77 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 9 hours
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS
