    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-da0556nia Product Specifications
165C6EA
Intel® Celeron® N4000 (1.1 GHz base frequency, up to 2.6 GHz burst frequency, 4 MB cache, 2 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 600
500 GB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD SVA anti-glare WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.77 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 13 hours and 15 minutes
Video Playback Battery life
Up to 11 hours and 15 minutes
HP Webcam with integrated digital microphone
Dual speakers
Pre-installed software
Netflix
