    Find Windows 11 and Windows 10 support help. Click here
HP ENVY x360 Laptop - 15m-ed0023dx Product Specifications
9HP24UA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
12 GB DDR4-3200 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
  • Intel® Iris® Plus Graphics
  • Integrated
512 GB Intel® SSD
Optical drive
Optical drive not included
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 AC smart pin; 1 headphone/microphone combo
35.8 x 23 x 1.89 cm
1.92 kg
65 W AC power adapter
3-cell, 51 Wh Li-ion
HP Wide Vision HD Camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; 3 speakers
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix; Alexa; Biometric Fingerprint Reader
