    Fix Windows 10 Update Issues
HP Pavilion - 14-ce3750nd Product Specifications
2S762EA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (1 x 16 GB)
Video graphics
NVIDIA® GeForce® MX250 (4 GB GDDR5 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
32.68 x 22.55 x 1.79 cm
Starting at 1.6 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 6 hours and 15 minutes
Audio by B&O; Dual speakers; HP Audio Boost 1.0
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
