    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Product Specifications for the HP ENVY 6055 All-In-One Printer (5SE16A)
Product naming
Model name
5SE16A
What's included and accessories
What's in the box
HP ENVY 6055 All-in-One Printer; HP 67 Setup Black Instant Ink Ready Cartridge; HP 67 Setup Tri-Color Instant Ink Ready Cartridge; Regulatory flyer; Setup guide; Reference guide; Power cord (1.5 m) [For ink volume and page yield information, visit http://hp.com/go/learnaboutsupplies]
Accessories
None
Connectivity
Ports
1 Hi-Speed USB 2.0; 1 Wi-Fi 802.11ac (dual band)
Wireless capability
Yes, built-in Wi-Fi 802.11b/g/n
Copy
Copier settings
Color, mono
Color copy capability
Yes
Maximum number of copies
Up to 9 copies
Copy reduce / enlarge settings
25 to 200%
Copy resolution
300 x 300 dpi
Environmental
Acoustic power emissions (active, printing)
6.7 B(A)
Acoustic pressure emissions
56 dB(A) (printing at 5 ppm)
Recommended operating humidity range
25 to 75% RH (non-condensing)
Non-Operating Humidity Range
20 to 80% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
The HP Envy 6000 All-in-One series is made from recycled printers and other electronics—more than 20% by weight of plastic. Save paper by up to 50% using automatic two-sided printing. Original HP cartridges have been engineered to use recycled plastic and help meet HP’s demanding standards for quality and reliability.
Fax
Fax available
No
Mobile printing capability
Mobile printing services
HP Smart app; Apple AirPrint™; Mopria™-certified
Paper handling
Input capacity
Up to 100 sheets
Standard input capacity (cards)
Up to 40 cards
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media sizes supported (U.S. standard)
Letter, 4 x 6 in, 5 x 7 in, 8 x 10 in, No. 10 envelopes
Media sizes, custom (metric)
Simplex: 76.2 x 127 mm to 216x297mm; Duplex: 76.2 x 127 mm to 216x297mm
Media sizes, custom (U.S. standard)
Simplex:3x5 to 8.5x11.7; Duplex:3 x 5.5 to 8.5 x 11.7
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers; Plain Paper, Light/Recycled
Media weight supported (metric)
A4: 60 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP cards: up to 200 g/m²; HP 10 x 15 cm photo paper: up to 300 g/m²
Media weight supported (U.S. standard)
20 lb
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Letter; Executive
Physical dimensions
Maximum dimensions (W x D x H, metric)
432.5 x 511.5 x 132.1 mm
Maximum dimensions (W x D x H, U.S. standard)
17.03 x 20.14 x 5.2 in
Weight (metric)
5.22 kg
Weight (U.S. standard)
11.51 lb
Power
Built-in Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz, 0.7A
Power consumption
0.10 Watts (Off) , 4.0 Watts (Ready) , 1.70 Watts (Sleep)
Print cartridges
Number of print cartridges
2 (1 each black, tri-color)
Replacement cartridges
NA and AP Developed Markets: HP 67 Black Original Ink Cartridge (~120pgs yield) 3YM56AN; HP 67XL Black High Yield Original Ink Cartridge (~240pgs yield) 3YM57AN; HP 67XXL Black Extra High-Yield Original Ink Cartridge (~400pgs yield) 3YM59AN; HP 67 Tri-Color Original Ink Cartridge (~100pgs yield) 3YM55AN; HP 67XL Tri-Color High-Yield Original Ink Cartridge (~200pgs yield) 3YM58AN; NA Developed Markets ONLY: HP 67XXL Tri-Color Extra High-Yield Original Ink Cartridge (~330pgs yield) 6ZA16AN. EMEA Markets: HP 305 Black Original Ink Cartridge (~120pgs yield) 3YM61AE; HP 305XL Black High-Yield Original Ink Cartridge (~240pgs yield) 3YM62AE; HP 307XL Black Extra High-Yield Original Ink Cartridge (~400pgs yield) 3YM64AE; HP 305 Tri-Color Original Ink Cartridge (~100pgs yield) 3YM60AE; HP 305XL Tri-Color High-Yield Original Ink Cartridge (~200pgs yield) 3YM63AE; APJ Emerging Markets: HP 805 Black Original Ink Cartridge (~120pgs yield) 3YM73AA; HP 805XL Black High-Yield Original Ink Cartridge (~240pgs yield) 3YM71AA; HP 805 Tri-Color Original Ink Cartridge (~100pgs yield) 3YM72AA; HP 805XL Tri-Color High-Yield Original Ink Cartridge (~200pgs yield) 3YM70AA. Actual yield varies considerably based on content of printed pages and other factors. For details see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic (standard)
Print speed black (ISO)
Up to 10 ppm
Print speed color (ISO)
Up to 7 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Regulatory specifications
Regulatory model number
SNPRC-1807-01
Safety
EN 60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013 IEC 60950-1:2005 +A1:2009 +A2:2013 EN 62368-1:2014+A11:2017 IEC 62368-1:2014 EN 62479:2010 EN 62311:2008
Electromagnetic compatibility
CISPR 32:2012 / EN 55032:2012 Class B CISPR 32:2015 / EN 55032:2015 Class B CISPR 24:2010 / EN 55024:2010 CISPR 35:2016 / EN 55035:2017 FCC CFR 47 Part 15 Class B ICES-003, Issue 6 VCCI-CISPR 32:2016 EN 301 489-1 V2.1.1:2017 EN 301 489-17 V3.1.1:2017
Telecom compliance (fax capability)
EN 300 328 V2.1.1:2016 EN 301 893 V2.1.1:2017
Scan
Scan technology
CIS
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
215.9 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
MacOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14, macOS Catalina v10.15, 2 GB Available Space, Internet Access
Recommended Macintosh system requirements
MacOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14, macOS Catalina v10.15, 2 GB Available Space, Internet Access.
Compatible Network Operating Systems
Windows 10, 7; MacOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14, macOS Catalina v10.15
One-year limited hardware warranty; 24-hour, 7 days a week support
