    Fix Windows 10 Update Issues
    Are you working from home?
Document ID: c06587149
Version: 1
HP Engage Go Convertible Systems - Dock Firmware Auto Update Fails With BIOS Version 01.08 or Later
Release date : 05-Mar-2020
Last updated : 10-Mar-2020
DESCRIPTION
The dock firmware update fails with BIOS versions 01.08 to 1.10. The issue occurs if the computer is not docked when the BIOS update is performed.
SCOPE
BIOS:
  • Version 1.08
  • Version 1.09
  • Version 1.10
Systems:
  • HP Engage Go Mobile Systems
  • HP Engage Go Convertible System
RESOLUTION
Avoid the issue by docking the computer prior to updating the BIOS.
Resolve the issue using one of the following options:
Option 1. Dock the computer and reinstall the BIOS.
Option 2. Dock the computer, locate the SoftPaq folder, then run HpFirmwareUpdRec64.exe.
NOTE: The issue will be fixed in a future BIOS version.
Hardware platforms affected : HP Engage Go Convertible System, HP Engage Go Mobile System
Support Communication Cross Reference ID : IA06587149
