    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Fix Windows 10 Update Issues
HP Display Center
This document will help you use HP Display Center to configure the display settings.
Using the software
In the left-side pane, select the monitor you want to configure, and then use the DISPLAY, COLOR, INPUT, VIEW, and ADVANCED tabs to change the settings.
The available settings might vary, depending on the capabilities of your monitor.
To restore default settings, select Reset to default.
Display tab
On the DISPLAY tab, you can adjust the Brightness, Contrast, Sharpness, and Black Stretch settings.
Reducing the Brightness setting might decrease your monitor power consumption. HP Display Center provides a power consumption estimate.
Color tab
On the COLOR tab, you can configure the Color and Custom RGB settings.
Input tab
On the INPUT tab, you can configure the Input Source, Resolution, and Speaker settings.
View tab
On the VIEW tab, you can configure the Pivot and Desktop Partition settings.
To create a desktop partition:
  1. Click the plus sign (+).
  2. Follow the on-screen instructions to create vertical and horizontal lines.
  3. Click Save.
Advanced tab
On the ADVANCED tab, you can change the Theft Deterrence, OSD Controls, Batch Controls, Firmware Update, and Power Savings settings.
Changing the brightness with keyboard shortcuts
To increase the display brightness, press the Ctrl and Up arrow keys. To decrease brightness, press the Ctrl and Down arrow keys.
To change or restore the default keyboard shortcuts, use these steps:
  1. In the left-side pane, click Settings.
  2. In the To increase box, type a keyboard shortcut to increase the brightness setting, or click Reset to restore the default shortcut.
  3. In the To decrease box, type a keyboard shortcut to decrease the brightness setting, or click Reset to restore the default shortcut.
  4. Click Save.
Importing and exporting settings
You can import or export files containing display settings.
Importing settings
To import a CSV file:
  1. Select Import.
  2. Select the CSV file, and then select Open.
Exporting settings
To export your display settings:
  1. Configure your display.
  2. Select Export.
  3. Select the folder to save the .exe file to, and then select OK.
  4. On a different display, run the .exe file.
