    Are you working from home?
    Fix Windows 10 Update Issues
Product Specifications for the HP Neverstop Laser MFP 1201n (5HG89A)
Product naming
Model name
5HG89A
What's included and accessories
What's in the box
HP Neverstop Laser 1201n Printer; Preinstalled HP Black Original Imaging Drum (5,000 pages yield, 20,000 pages useful life); Reference guide; Setup guide; Regulatory flyer; Support flyer; Warranty guide; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port; Fast Ethernet 10/100 Base
Wireless capability
No
Copy
Copier settings
Number of Copies; Lighter/Darker; Optimise; Paper
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (black, normal)
Up to 14 cpm
Copy resolution
Up to 600 x 600 dpi (flatbed)
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Recommended operating humidity range
30 to 70% RH
Recommended operating temperature range (Celsius)
17.5 to 25°C
Storage temperature range (Celsius)
-20 to 50°C
Environmental specifications
Mercury-free
Memory
Memory
64 MB
Maximum Memory
64 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Google Cloud Print™; HP Smart App; Mopria™ Certified
Mobile printing compatibility note
Apple AirPrint: Mobile device must have AirPrint®; Google Cloud Print™ 2.0: Requires Google Cloud Print™ registration and Google account. Learn more at http://www.hp.com/go/mobileprinting.
Networking
Network protocols, supported
TCP/IP: IPv4; IPv6; IP Direct Mode; LPD; SLP; Bonjour; WS-Discovery; BOOTP/DHCP/AutoIP; SNMP v 1/2/3; HTTP/HTTPS
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A6; A5; A4; No.10 Env; C5 Env; DL Env; B5(JIS); Oficio 216 x 340; 105 x 148.5 mm to 216 x 356 mm
Media sizes, custom (metric)
Media types
Plain paper; Heavy paper; Bond paper; Label; Light paper; Envelope
Media weight supported (metric)
60 to 120 g/m²
Physical dimensions
Maximum dimensions (W x D x H, metric)
380.5 x 385 x 521 mm
Weight (metric)
8.73 kg
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology
Internal (Built-in) power supply
Power supply
220V - 240V nominal at +/-10% (min 198V, Max 264V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz)
Power consumption
338 watts (active printing), 3.3 watts (ready), 0.95 watts (sleep), 0.1 watts (manual off)
Print cartridges
Number of print cartridges
1 Imaging Drum
Replacement cartridges
HP 143A Black Original Neverstop Laser Toner Reload Kit (2,500 pages); HP 143AD Dual pack Black Original Neverstop Laser Toner Reload Kit (2 x 2,500 pages); HP 144A Black Original Laser Imaging Drum (includes 5,000 pages of inbox toner, useful life of 20,000 pages)
Replacement cartridges footnote
Declared black toner page yield value in accordance with ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies
SureSupply note
HP SureSupply alerts you when your print cartridge is running low and helps you purchase online or locally through HP or a participating retailer. For more information, visit http://www.hp.com/go/SureSupply; only available with Original HP supplies; Internet access required.
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 600 x 600 x 2 dpi
Maximum print area (metric)
216 x 356 mm
Monthly duty cycle
Up to 20,000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
Apple AirPrint™, Mopria Certified, HP Auto-On/Auto-Off, HP Smart App, HP Smart Task
Regulatory specifications
Safety
IEC 60950-1:2005+A1:2009+A2 2013 (International); EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 (EU); IEC/EN 60825-1:2014 (Class 1 Laser Product); EN 62479:2010/IEC 62749:2010; Low Voltage Directive 2006/95/EC with CE Mark (Europe); Compliance with Laser safety standards 21 CFR 1002.10 and 1002.11 except for deviations pursuant to Laser notice No. 50, Dated June 24, 2007; Other safety approvals as required by individual countries IS 13252(PART 1):2010
Electromagnetic compatibility
EN 61000-3-2:2014, EN 61000-3-3:2013, EN 55024:2010, EN 55032:2012/AC:2013, ICES-003 Issue 5, GB/T 9254-2008, GB 17625.1-2012, CISPR 22:2008, CISPR 32:2012, other EMC approvals as required by individual countries).
Scan
Scanner advanced features
No
Scan technology
D-CIS
Scan resolution, hardware
Up to 600 ppi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
Twain version
Version 2.1 (Windows 7 or higher)
System requirements
Minimum system requirements for Windows
Windows® 10, 8, 7: 32/64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer
Minimum System Requirements for Macintosh
Apple®OS X EI Capitan (v10.11), macOS Sierra (v10.12), macOS High Sierra (v10.13), 1.5 GB available hard disk space, Internet required, USB
Compatible Network Operating Systems
Windows® 10, 8, 7: 32/64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Apple®OS X EI Capitan (v10.11), macOS Sierra (v10.12), macOS High Sierra,(v10.13), 1.5 GB available hard disk space, Internet required; USB Linux (for more information, see https://www.developers.hp.com/hp-linux-imaging-and-printing)
Operating system (supported note)
Not supporting Windows® XP (64-bit) and Windows Vista® (64-bit); Not all "Compatible Operating Systems" are supported with in-box software; Full solution software available only for Windows 7 and newer; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed; Windows RT OS for Tablets (32/64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
One-year limited hardware warranty. For more info, please visit us at https://www.support.hp.com
