To prevent this issue from occurring, please upgrade to latest BIOS before proceeding to install or update to the latest Windows 10 version 2004 or re-installing the KB4524244 or KB4535680.
To recover from this issue, perform the following steps:
- Power on or restart the computer.
- If the HP Sure Start Recovery warning message appears, select
OK.
If the computer boots successfully into Windows, do not install the updates. The updates will continue to fail when installed.
If the computer does not boot into Windows successfully, then proceed to Step 3.
- Press the
F10 key to enter
HP Computer Setup (F10 Setup).
- Select
Security>BIOS Sure Start.
- Uncheck the
Sure Start Secure Boot keys protection option to disable it.
Save changes and exit the BIOS.
- Complete the pending Windows update installation. After the performing the updates, manually re-enable
Sure Start Secure Boot keys protection option.
- Restart the computer.
- Press the
F10 key to enter
- Select
- Check the
Sure Start Secure Boot keys protection option to enable.
NOTE: If the issue persists, then refer to the following article:
NOTE: Microsoft has removed the Windows update (KB4524244) and will no longer offer this
KB4524244. This update will be re-released as KB4535680 by January 10/2021.
If the latest supported BIOS is not installed on the system, then Windows 2004 installation, Windows 2004 Update, or the KB4524244 or KB4535680 update may be blocked for installation or download.
HP recommends that the latest BIOS is installed before updating or installing Windows 2004 or installing the KB4524244 or KB4535680.
Models Affected
BIOS Version
Download SoftPaq
HP EliteDesk 705 G4 Microtower PC
02.13.00
HP EliteDesk 705 G4 Workstation Edition
02.13.00
HP EliteDesk 705 G4 Small Form Factor PC
02.13.00
HP EliteDesk 705 65W G4 Desktop Mini PC
02.13.00
HP EliteDesk 705 35W G4 Desktop Mini PC
02.13.00
HP EliteDesk 705 G5 Small Form Factor PC
02.06.00
HP EliteDesk 705 G5 Desktop Mini HP PC
02.06.00
HP ProDesk 405 G4 Small Form Factor PC
02.13.00
HP EliteBook 745 G6 Notebook PC
01.06.00
HP EliteBook 735 G6 Notebook PC
01.06.00
HP MT45 THIN CLIENT
01.06.00
HP EliteBook 745 G5 Notebook PC
01.12.00
HP EliteBook 755 G5 Notebook PC
01.12.00
HP EliteBook 735 G5 Notebook PC
01.12.00
HP MT44 THIN CLIENT
01.12.00
HP ProBook 645 G4 Notebook PC
01.12.00
