    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
    Fix Windows 10 Update Issues
HP PrinterOn Enterprise - Can the PrinterOn Print Print Delivery Station (PDS) be installed directly on the printer?
Yes, PrinterOn does have the embedded Print Delivery Station (PDS) agent that could replace the software installed on a Windows machine.
Currently these agents are limited to some Ricoh and Samsung printers.
For additional details and the availability on the embedded-technology, consult with your service/solution provider.
Applies to PrinterOn Print Delivery Station 3.x and later.
