    Are you working from home?
    Fix Windows 10 Update Issues
HP Notebook - 15-db0464ur Product Specifications
9FD44EA
AMD A9-9425 Dual-Core (3.1 GHz base clock, up to 3.7 GHz max boost clock, 1 MB cache)
4 GB DDR4-1866 SDRAM (1 x 4 GB)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.77 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 30 minutes
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS
