    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-db1154ur Product Specifications
9PP14EA
AMD Athlon™ 300U with Radeon™ Vega 3 Graphics (2.4 GHz base clock, up to 3.3 GHz max boost clock, 3 MB cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
  • AMD Radeon™ Vega 3 Graphics
  • Integrated
  • AMD Radeon™ 530 Graphics (2 GB GDDR5 dedicated)
  • Discrete
128 GB M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
Starting at 1.8 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS
