    Fix Windows 10 Update Issues
OMEN by HP 15-dc1106tx Product Specifications
8US37PA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
36 x 26.3 x 2.6 cm
2.32 kg
150 W AC power adapter
3-cell, 52 Wh Li-ion polymer
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP JumpStart; HP Support Assistant; OMEN Command Center; HP Connection Optimizer; HP PC Hardware Diagnostics Windows; HP BIOS Recovery
Pre-installed software
iQiyi
