HP Chromebook x2 12-f000 - Components
Right side
Figure : Identifying the right-side components
Component
(1)
USB Type-C power connector and charging port
Connects an AC adapter that has a USB Type-C connector, supplying power to the computer and, if needed, charging the computer battery.
– and –
Connects a USB device that has a Type-C connector, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
(2)
AC adapter and battery light
  • White: The AC adapter is connected and the battery is charged.
  • Amber: The AC adapter is connected and the battery is charging.
  • Off: The computer is using battery power.
(3)
Volume button
Controls speaker volume on the tablet.
(4)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
  warning:
To reduce the risk of personal injury, adjust the volume before putting on headphones, earbuds, or a headset. For additional safety information, refer to the Regulatory, Safety, and Environmental Notices.
This guide is provided in the box.
When a device is connected to the jack, the computer speakers are disabled.
Left side
Figure : Identifying the left-side components
Component
(1)
Memory card reader
Reads optional memory cards that enable you to store, manage, share, or access information.
To insert a card:
  1. Hold the card label-side up, with connectors facing the computer.
  2. Insert the card into the memory card reader, and then press in on the card until it is firmly seated.
To remove a card:
  1. Pull out the card.
(2)
(3)
USB Type-C power connector and port
– and –
Figure : Identifying the display components
Component
(1)
Speakers (2)
Produce sound.
(2)
WLAN antennas*
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
(3)
Internal microphone
Records sound.
(4)
Ambient light sensor (select products only)
Automatically adjusts the display brightness based on the lighting conditions in your environment.
(5)
Camera light
On: The camera is in use.
(6)
Camera
Allows you to video chat, record video, and record still images.
*The antennas are not visible from the outside of the computer, and antenna location varies. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
Rear display
Figure : Identifying the rear display components
Component
(1)
Rear internal microphone
Records sound.
(2)
Rear camera
Top edge
Component
Power button
  • When the computer is off, press the button to turn on the computer.
  • When the computer is in the Sleep state, press the button briefly to exit Sleep.
  • When the computer is on and you want to lock the screen, press the button until you see the sign-in screen appear. Pressing the power button during screen-lock mode turns off the computer.
  • When the computer is on and you want to turn it off, press and hold the button to lock the screen, and then continue to press the button until the computer turns off.
Bottom edge
Figure : Identifying the bottom edge components
Component
(1)
Alignment posts (2)
Guide the keyboard to the correct connection with the tablet.
(2)
Docking port
Connects the tablet to the keyboard base.
Labels
The labels affixed to the computer provide information you may need when you troubleshoot system problems or travel internationally with the computer. Labels may be in paper form or imprinted on the product.
Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
  • Service label—Provides important information to identify your computer. When contacting support, you may be asked for the serial number, the product number, or the model number. Locate this information before you contact support.
    Your service label will resemble one of the examples shown below. Refer to the illustration that most closely matches the service label on your computer.
    Figure : Identifying the service label
    Component
    (1)
    HP product name
    (2)
    Model number
    (3)
    Product ID
    (4)
    Serial number
    (5)
    Warranty period
    Component
    (1)
    HP product name
    (2)
    Product ID
    (3)
    Serial number
    (4)
    Warranty period
  • Regulatory label(s)—Provide(s) regulatory information about the computer.
  • Wireless certification label(s)—Provide(s) information about optional wireless devices and the approval markings for the countries or regions in which the devices have been approved for use.
