HP ProDesk 405 G4 Small Form Factor PC Specifications
Product image
Operating systems
Specification
Pre-installed (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
Windows 10 Pro 64
Windows 10 Enterprise 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Pre-installed (other)
FreeDOS 1.2
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
AMD Ryzen 5 PRO 2400G APU
65 W
Up to 3.9 GHz maximum Turbo Frequency (3.6 GHz base frequency)
6 MB cache, 4 cores
AMD Radeon Vega Graphics
AMD Ryzen 3 PRO 2200G APU
65 W
Up to 3.7 GHz maximum Turbo Frequency (3.5 GHz base frequency)
6 MB cache, 4 cores
AMD B350 FCH
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations.
Memory
Specification
DDR4-2666
Transfer rates up to 2666 MT/s
Actual data rate is determined by both the system configured processor and memory module installed.
Maximum
64 GB
Number of slots
(4) DIMM
Configurations
4 GB total system memory (4 GB x 1)
8 GB total system memory (4 GB x 2)
8 GB total system memory (8 GB x 1)
16 GB total system memory (8 GB x 2)
16 GB total system memory (16 GB x 1)
32 GB total system memory (16 GB x 2)
32 GB total system memory (8 GB x 4)
64 GB total system memory (16 GB x 4)
Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.
Memory modules support data transfer rates up to 2666 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Graphics
Specification
Integrated
Radeon Vega 11 Graphics
Radeon Vega 8 Graphics
Integrated graphics varies by processor.
Discrete (optional)
NVIDIA GeForce GT 730 2 GB DP DVI PCIe x8
AMD Radeon RX 550X 4 GB LP PCIe x16 DP HDMI
AMD Radeon R7 430 2 GB LP PCIe x16 2DP 64-bit
Storage
Specification
SATA HDDs (3.5 in)
500 GB 7200 RPM
1 TB 7200 RPM
2 TB 7200 RPM
SATA HDDs (2.5 in)
500 GB 7200 RPM
500 GB 7200 RPM Removable
500 GB 7200 RPM, Self Encrypted Drive OPAL 2
1 TB 7200 RPM
SATA SDDs (2.5 in)
256 GB SATA TLC
512 GB SATA TLC
256 GB SATA TLC Removable
512 GB SATA TLC Removable
256 GB SATA Self Encrypted OPAL 2 TLC
512 GB SATA Self Encrypted OPAL 2 TLC
256 GB SATA Self Encrypted OPAL 2 TLC Removable
512 GB SATA Self Encrypted OPAL 2 TLC Removable
PCIe NVMe TLC SSD drives
128 GB M.2 2280 PCIe NVMe
256 GB M.2 2280 PCIe NVMe
512 GB M.2 2280 PCIe NVMe
128 GB M.2 2280 PCIe Gen3 x2 NVMe TLC
256 GB M.2 2280 PCIe NVMe TLC
512 GB M.2 2280 PCIe NVMe TLC
1 TB M.2 2280 PCIe NVMe TLC
256 GB M.2 2280 PCIe NVMe Self Encrypted OPAL 2 TLC
512 GB M.2 2280 PCIe NVMe Self Encrypted OPAL 2 TLC
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
Keyboards/pointing devices
Specification
Keyboards
HP Wireless Business Slim Keyboard and Mouse
HP USB Business Slim Keyboard
HP USB Business Slim Smart Card CCID Keyboard
HP USB (Grey) Business Slim Keyboard
HP PS/2 Business Slim Keyboard
HP USB Keyboard
HP USB Value Keyboard
Mice
HP PS/2 Mouse
HP USB Optical Mouse
HP 1000dpi Laser Mouse USB
HP Hardened USB Mouse
HP USB Fingerprint Reader Mouse
Availability might vary by country/region.
Networking/communications
Specification
Ethernet (RJ-45)
Realtek RTL8111EPH (standard)
Intel Ethernet I210-T1 PCIex1 Gb NIC
Wireless LAN (optional)
Intel 9260 802.11 AC 2x2 and Bluetooth 5 PCIe non-vPro
Realtek RTL8822BE AC 2x2 and Bluetooth 4.2 LE M.2 2230
Realtek RTL8821CE AC 1x1 and Bluetooth 4.2
Wireless access point and internet service required and not included. Availability of public wireless access points limited.
Audio/multimedia
Feature
Audio (integrated)
Conexant CX20632
2 W class D mono amplifier for the internal speaker only
(1) Headset connector supports a CTIA style headset and is retaskable as a Line-in, Line-out, Microphone-in or Headphone-out port (front)
(1) Headphone port (front)
Ports/slots/bays
Specification
Ports
Standard
(2) Dual-Mode DisplayPort 1.2 (rear)
When configurable I/O port has been configured, one DisplayPort might be blocked in select configurations.
(4) USB 3.1 Gen 1 ports (2 front; 2 rear)
(2) USB 3.0 Type-C (1 front; 1 rear (optional))
(1) Headphone (front)
(1) Universal Audio Jack with CTIA headset support (front)
(1) RJ-45 Ethernet (rear)
Optional
(1) DisplayPort 1.2, HDMI 2.0, VGA, or USB Type-C with display output or serial)
(1) M.2 PCIe x1 2230 (for WLAN)
(1) M.2 PCIe x4 2280/2230 Combo (for storage)
(1) PCI Express x1 (v3.0)
(1) PCI Express x16 (v3.0)
Bays
(1) 9.5 mm Slim ODD
(1) Secure Digital (SD) Reader
(2) 2.5 in internal storage drive
SFF can be configured with either (1) 3.5 in or (2) 2.5 in internal storage drive (2.5 in drive needs adapter).
(1) 3.5 in internal storage drive
Software/security
Specification
BIOS
BIOS Update via Network
Power On Authentication
Master Boot Record Security
Absolute Persistence Module1
Pre-boot Authentication
HP Value Add Software
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Noise Cancellation Software
HP Privacy Settings
HP Support Assistant (requires Windows and internet access)
HP Sure Click (available on select HP platforms and supports Microsoft Internet Explorer, Google Chrome, and Chromium.
Microsoft Products
Buy Office (sold separately)
Manageability
HP Driver Packs (available for download)
HP System Software Manager (SSM) (available for download)
HP Client Catalog (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Manageability Integration Kit Gen2 (available for download)
Client Security software
Microsoft Defender
HP Client Security Manager Gen4 (requires Windows and Intel 8th generation processors)
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Power-on password (via BIOS)
HP Secure Erase
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under the Software and Drivers section on the support page.
Power supply
Specification
External power supply
180 W Active PFC
90/92/89% efficient at 20/50/100% load (115 V)
91/93/90% efficient at 20/50/100% load (230 V)
Rated input current
250 W less than or equal to 3 A
400 W less than or equal to 5.2 A
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50 - 60 Hz
Operating line frequency
47 - 63 Hz
DC output
+12 V
Current leakage (NFPA 99: 2102)
Less than 500 µA of leakage current at 264 Vac with the ground wire disconnected, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 µA of leakage current at 264 Vac with the ground wire intact with normal polarity, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power cord
1.83 m (6.0 ft)
Physical specifications
Specification
Chassis (W x D x H)
95.0 x 270.0 x 296 mm (3.7 x 10.6 x 11.7 in)
Packaged (W x D x H)
399.0 x 230.0 x 499.0 mm (15.7 x 9.0 x 19.7 in)
System volume
463 cu in
7.6 L
System weight
5.88 kg (13.0 lb)
Shipping weight
7.32 kg (16.1 lb)
Environmental
Specification
Certifications
EPEAT Gold (registered where applicable/supported)
Registration status varies by country/region.
Waste Electrical and Electronic Equipment (WEEE)
FCC
UL
Low Voltage Directive IEC950
ETS
RoHS
