    Fix Windows 10 Update Issues
HP Pavilion Gaming - 15-ec0003nt Product Specifications
7WG37EA
AMD Ryzen™ 7 3750H with Radeon™ RX Vega 10 Graphics (2.3 GHz base clock, up to 4 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (HP Sleep and Charge); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo; 1 RJ-45
36 x 25.7 x 2.35 cm
Starting at 2.25 kg
200 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
HP TrueVision HD Camera with integrated dual array digital microphone
B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS 1.2
