    Fix Windows 10 Update Issues
HP ENVY x360 - 15-dr1003ni Product Specifications
8UJ50EA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (1 x 16 GB)
Video graphics
  • Intel® UHD Graphics
  • Integrated
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass, 300 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo
35.9 x 24.6 x 1.72 cm
2.05 kg
65 W AC power adapter
4-cell, 55.67 Wh Li-ion
Battery life mixed usage
Up to 14 hours and 45 minutes
Video Playback Battery life
Up to 12 hours and 30 minutes
BANG & OLUFSEN; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix (30-day free trial offer)
