HP ProDesk 680 G4 Microtower PC - Illustrated Parts
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available for use when contacting support for assistance.
Figure : Identifying the computer serial number location
Computer major components
Access panel
Front bezel
SD card blank bezel
Dust filter
System boards (includes replacement thermal material):
Equipped with the NetC operating system
Equipped with the NetC and Windows 10 operating systems
Equipped with the Windows 10 operating system
Equipped with a non-Windows operating system
Processors:
Intel Core i7-8700 3.2-GHz processor (2666 MHz front-side bus [FSB], 12 MB SmartCache, six cores)
Intel Core i5-8600 3.1-GHz processor (2666 MHz FSB, 9 MB SmartCache, six cores)
Intel Core i5-8500 3.0-GHz processor (2666 MHz FSB, 9 MB SmartCache, six cores)
Intel Core i3-8100 3.6-GHz processor (2400 MHz FSB, 6 MB SmartCache, quad core)
Intel Core i3-8033 3.7-GHz processor (2400 MHz FSB, 8 MB SmartCache, quad core)
Intel Pentium Gold G5400 3.7-GHz processor (2400 MHz FSB, 4 MB SmartCache, dual core)
Intel Celeron G4900 3.1-GHz processor (2 MB SmartCache, dual core)
Power supply (includes cables and plastic cable ties):
400 W, 12 V, 92 percent, 3 out connectors
250 W, 12 V, 92 percent high volume, 1 out connector
180 W, 12 V, 90 percent high volume, 1 out connector
Fan-sink, 65 W (includes retention-clips)
Fan (includes cable)
Speaker, 40×28.5 mm, 2 W, 4 ohm, 140 mm (includes cable)
Hood sensor module
Port modules:
HP Parallel port PCIe×1 card
PS/2 + serial port combination module
Serial port module
Optical drive:
DVD-BluRay 6× Writer Drive, 9.5-mm, slim tray
DVD±RW SuperMulti Dual Layer Drive, 9.5-mm, slim tray
DVD-ROM Drive, 9.5-mm, slim tray
Slim optical drive bezel
Optical drive latch, 9.5-mm
Networking:
Intel 9260 802.11ac non-vPro PCIe×1 Card
Intel 9560 ac 2×2 + Bluetooth 5 non-vPro Card WW
Intel 9560 ac 2×2 + Bluetooth 5 vPro Card WW
Intel PRO/1000 Single Port GbE network interface card
Realtek 8822BE 802.11ac PCIe×1 Card
Realtek ac 2×2 + Bluetooth 4.2 LE M.2 2230 PCIe + USB Card WW
Realtek ac 1×1 + Bluetooth 4.2 LE M.2 2230 PCIe + USB Card WW
Antenna cover
Internal wireless antenna cable assembly
Memory modules (4, DDR4-2666, NECC, UDIMM):
16 GB
8 GB
4 GB
Hard drive:
2 TB, 7200 rpm, 3.5 in.
2 TB, 5400 rpm, 7.0 mm
1 TB, 7200 rpm, 3.5 in.
1 TB, 7200 rpm, 9.5 mm
1 TB, 7200 rpm, 7.0 mm
500 GB, 7200 rpm, 3.5 in.
500 GB, 7200 rpm, 7.0 mm
Solid-state drive:
1-TB, M2 2280, Non Volatile Memory express (NVMe) solid-state drive with secure seal (SS) and triple-level cell (TLC)
512-GB, M2 2280, NVMe, peripheral component interconnect express (PCIe) solid-state drive with SS and TLC
512-GB, M2 2280, NVMe, PCIe solid-state drive
512-GB, SATA-3 solid-state drive with TLC
280-GB, NVMe, PCIe3×4, half-height, half-length (HHHL) solid-state drive
256-GB, M2 2280, NVMe, peripheral component interconnect express (PCIe) solid-state drive with SS and TLC
256-GB, M2 2280, NVMe, PCIe solid-state drive
256-GB, SATA-3 solid-state drive with TLC
128-GB, M2 2280, NVMe, PCIe solid-state drive with TLC
128-GB, M2 2280, NVMe, PCIe3×4 solid-state drive
118-GB, M2 2280, NVMe, PCIe, I/O solid-state drive
16-GB, M2 2280, NVMe, PCIe3×2 solid-state drive with TLC
Miscellaneous parts
Power cord with C13 receptacle, 1.83-meter (6.00-feet) for use in the People’s Republic of China
Adapters:
HP DisplayPort–to–DVI adapter
HP DisplayPort–to–HDMI 2.0 adapter
HP DisplayPort–to–VGA adapter
HP USB–to–Serial adapter (Sunix)
HP USB Type-C–to–DisplayPort adapter
HP USB Type-C–to–USB 3.0 adapter (EliteOne)
HP USB Type-C–to–USB Type-A hub
Cables:
DisplayPort 1.2 cable (1.83 m)
DVI monitor cable (Molex)
SATA data cable (straight–to–straight connector, 14 in., RoHS2, RF solution)
SATA data cable (straight–to–straight connector, 14 in., RoHS2)
SATA data cable (straight–to–straight connector, 9 in., RoHS2, RF solution)
SATA data cable (straight–to–straight connector, 9 in., RoHS2)
Drive power cable (straight–to–right-angle connector)
Wireless antenna cable (internal)
Expansion cards:
DisplayPort option board
HDMI option board
PCIe–to–RS232×1 option board
USB Type-C Generation 2 option board
VGA option board
Graphics cards:
AMD Radeon R7 430 2-GB 2DP Card
AMD Radeon R7 430 2-GB Card
AMD Radeon GTX 1060 6-GB FH G5 GFX Card
AMD Radeon RX550 4-GB FH PCIe×16 Card
AMD Radeon RX580 8-GB FH 3DP 1HDMI PCIe×16 GFX
Keyboards:
HP antimicrobial slim business keyboard for use in the People’s Republic of China
HP conferencing keyboard:
For use in the People’s Republic of China
For use in the United States
HP PS/2 slim Windows 8 keyboard:
HP USB essential keyboard:
HP USB slim ME keyboard:
HP USB slim SmartCard keyboard with CCID:
HP USB slim SmartCard ME keyboard with CCID:
HP USB slim Windows 8 keyboard:
Unbranded USB/PS2 BFR-PVC washable Windows 8 keyboard for use in the United States
HP wireless Windows 8 keyboard/mouse combination with dongle:
Mouse:
HP PS/2 optical mouse
HP USB antimicrobial mouse
HP USB fingerprint mouse
HP USB hardened mouse
HP USB laser mouse
HP USB optical mouse
Unbranded USB mouse
Unbranded USB PS/2 M12 ME washable mouse
