    Fix Windows 10 Update Issues
HP ZBook Studio G5 Mobile Workstation - Illustrated Parts
Computer major components
Figure : Identifying the computer major components
Item
Component
Spare part number
Display assembly: The touch screen display is spared as a whole unit assembly only. The non-touch display assembly is spared at the subcomponent level only. For non-touch display assembly spare part information, see Display assembly subcomponents.
(1)
Non-touch screen
not spared
(2)
Touch screen:
  • 15.6-in, UHD, UWVA, display assembly not equipped with a camera
L28663-001
  • 15.6-in, UHD, UWVA, display assembly equipped with a camera
L28664-001
(3)
Top cover with keyboard (includes keyboard cable):
For a detailed list of keyboard country codes, see Keyboard.
Backlit keyboard
L30668-xx1
Backlit, privacy keyboard
L30669-xx1
(4)
TouchPad
L32746-001
(5)
RTC battery
not spared
(6)
Top speaker
L28672-001 (Speaker Kit)
(7)
System board (includes processor and replacement thermal material):
All system boards use the following part numbers:
xxxxxx-001: Non-Windows operating systems
xxxxxx-601: Windows 10 operating system
For use in models with discrete graphics memory:
  • Intel Xeon E-2186M processor
L30971-001, -601
  • Intel Xeon E-2176M processor
L30969-001, -601
  • Intel Core i7-8850H processor
L33161-001, -601
  • Intel Core i7-8750H processor
L33160-001, -601
  • Intel Core i5-8400H processor
L33159-001, -601
  • Intel Core i5-8300H processor
L33158-001, -601
For use in models with UMA graphics memory:
L28657-001, -601
L28656-001, -601
L31685-001, -601
L31684-001, -601
(8)
NFC module
L33682-001
(9)
Fingerprint reader board
L28662-001
(10)
Fingerprint reader bracket
L28674-001 (Bracket Kit)
(11)
Card reader board/audio board (includes cable)
L28660-001
Thermal module (includes replacement thermal material):
(12)
For use only with models with discrete graphics memory
L28670-001
(13)
For use only with models with UMA graphics memory
L30973-001
(14)
Power button board (includes cable)
L28661-001
Speaker Kit
L28672-001
(15)
Left speaker
(16)
Right speaker
(17)
Memory module (DDR4-2400-MHz)
For use with Core processors:
  • 16 GB
937438-850
  • 8 GB
937236-850
  • 4 GB
L10598-850
For use with Xeon processors:
  • 16 GB, ECC
L24981-001
  • 8 GB, ECC
L24983-001
(18)
Memory cover
(19)
Solid-state drive (M.2)
2-TB, PCIe, TLC
L28681-001
1-TB, PCIe, TLC
L28677-001
512-GB, PCIe, TLC
L28683-001
512-GB, PCIe, self-encrypting drive (SED), OPAL 2, TLC
L28682-001
512-GB, SATA, FIPS, TLC
L28684-001
360-GB, PCIe, TLC
L28685-001
256-GB, PCIe, TLC
L28679-001
256-GB, PCIe, self-encrypting drive (SED), OPAL 2
L28678-001
256-GB, SATA-3, self-encrypting drive (SED), OPAL 2
L28680-001
Optane memory module, 16-GB
L28676-001
(20)
WWAN module
HP lt4132 LTE/HSPA+ 4G Mobile BroadBand Module (LTE CAT4: Huawei HP lt4132, LTE/HSPA+ w/GPS M.2)
845710-003
Intel XMM 7360 LTE-Advanced (LTE CAT9: Fibocom lt4210 LTE/HSPA+ w/GPS)
L15398-001
(21)
WLAN module
Intel Wireless-AC 9560 802.11ac 2x2 WiFi + Bluetooth 5 Combo Adaptor (non vPro)
L32650-005
Intel Wireless-AC 9560 802.11ac 2x2 WiFi + Bluetooth 5 Combo Adaptor (vPro)
L32652-005
(22)
Hard drive cable
L28668-001 (Cable Kit)
(23)
Hard drive (2.5 inch)
2 TB, 5400 rpm
912487-850
2 TB, 5400 rpm, hybrid 8 GB SSD
929167-850
1 TB, 7200 rpm
L06427-850
1 TB, 5400 rpm, hybrid 8 GB SSD
924036-850
500 GB, 7200 rpm
703267-001
500 GB, 7200 rpm, FIPS-140-2
820572-001
500 GB, 7200 rpm, self-encrypting drive (SED)
820573-001
500 GB, 5400 rpm, hybrid 8 GB SSD
732000-001
Solid-state drive (2.5 inch)
1 TB, SATA, TLC
L28686-001
256 GB, SATA, TLC
L28687-001
(24)
Hard drive brackets
L33681-001 (Hard Drive Hardware Kit)
(25)
Battery (4-cell)
L07046-855
(26)
Battery (6-cell)
L07045-855
(27)
Bottom cover
L28666-001
Plastics Kit
Figure : Identifying the Plastics Kit components
Item
Component
Spare part number
Plastics Kit
L28675-001
(1)
Card reader insert
(2)
MicroSIM insert
(3)
MicroSIM holder insert
(4)
Fingerprint reader insert
(5)
Central hook
Figure : Identifying the LED display assembly subcomponents
Item
Component
Spare part number
(1)
Display bezel
For use in models with an ambient light sensor:
  • Equipped with only an HD camera
L31689-001
  • Equipped with an IR camera
L31690-001
  • Not equipped with a camera
L31691-001
For use in models without an ambient light sensor
L31692-001
L31693-001
L31694-001
(2)
Display panel (includes display cable, bezel adhesive, and panel adhesive tape)
FHD
L32562-001
FHD, privacy
L32561-001
UHD
L32563-001
(3)
Hinge cap (left and right; includes bezel adhesive)
L31695-001
(4)
Display hinges (includes left and right hinges and bezel adhesive)
L28659-001
(5)
Antenna (left and right, includes bezel adhesive)
L31688-001
(6)
Camera module, IR camera (includes bezel adhesive)
L30660-001
(7)
Camera cable, IR (separate cables for IR camera, IR camera on DreamColor display, IR camera on displays without an ambient light sensor; includes bezel adhesive, cover adhesive)
L31696-001 (Display Cable Kit)
(8)
Camera module, HD (includes bezel adhesive)
L28470-001
(9)
Camera cable, HD (separate cables for HD camera, HD camera on DreamColor displays; includes bezel adhesive, cover adhesive)
(10)
Display enclosure (includes bezel adhesive)
FHD display
L31686-001
UHD display
L31687-001
Privacy display
L28658-001
Camera shutter (not illustrated)
L31319-001
Mass storage devices
Figure : Identifying the mass storage devices
Item
Component
Spare part number
(1)
2 TB, 5400 rpm
912487-850
929167-850
1 TB, 7200 rpm
L06427-850
924036-850
500 GB, 7200 rpm
703267-001
820572-001
820573-001
732000-001
1-TB, SATA, TLC
L28686-001
256-GB, SATA, TLC
L28687-001
(2)
Hard drive brackets (for use in non-touch screen models)
(3)
Hard drive bracket (for use in touch screen models)
(4)
Solid-state drive
2-TB, PCIe, TLC
L28681-001
1-TB, PCIe, TLC
L28677-001
512-GB, PCIe, TLC
L28683-001
L28682-001
L28684-001
360-GB, PCIe, TLC
L28685-001
256-GB, PCIe, TLC
L28679-001
L28678-001
L28680-001
L28676-001
Bracket Kit
Figure : Identifying the bracket kit components
Item
Component
Spare part number
Bracket Kit
L28674-001
(1)
LCD clip
(2)
Power connector bracket (separate brackets for use in non-touch and touch screen models)
(3)
Memory cover
(4)
(5)
(6)
Left and right hard drive brackets (for use in non-touch models)
Miscellaneous parts
Component
Spare part number
AC adapter, 150-W HP Smart adapter (PFC, 4.5-mm)
L32661-001
Rubber Kit
L28671-001
Cable Kit (includes hard drive connector cable, fingerprint reader cable, TouchPad cable, and NFC cable)
L28668-001
Adapters
HP HDMI to DVI adapter
749038-001
HP HDMI to VGA adapter
701943-001
HP USB to Gigabit RJ-45 adapter
829941-001
HP USB Type-C to VGA adapter
831751-001
HP USB Type-C to HDMI adapter
831752-001
HP USB Type-C to DisplayPort adapter
831753-001
HP USB Type-C to RJ-45 adapter
855560-001
HP ZBook Thunderbolt 3, 1 meter cable
914966-001
HP Keyed Cable Lock, 10 mm
840158-001
HP Dual Head Keyed Cable Lock
840160-001
HP Stereo USB Headset
840340-001
HP Executive Slim Top Load Case
838256-001
HP 15.6 Business Top Load Case
L05334-001
HP USB Type-C Dock G4
L16133-001
HP USB External DVD+-RW Drive
747080-001
Mouse
HP USB Laser Mouse
674318-001
HP Comfort Grip Wireless Mouse
691922-001
HP Slim Bluetooth Mouse
746920-001
Screw Kit
L28673-001
