    Fix HP Printer issue on macOS
HP EliteDesk 800 G5 Desktop Mini PC - Illustrated Parts
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Computer major components
Figure : Computer major components illustrated
Item
(1)
Access panel
(2)
Front bezel
(3)
Front bezel dust filter (for use only in 35 W models)
(4)
Speaker
(5)
Hood sensor
(6)
Option boards:
HDMI option board
DisplayPort option board
VGA option board
(7)
Solid-state drives, NVMe, M.2 2280/2230, PCIe
1 TB, TLC
512-GB, TLC
512-GB
256-GB, TLC
256-GB, self-encrypting drive, TLC
Optane memory module, 16-GB
(8)
Memory module (SODIMM, DDR4-2666 or DDR4-2400)
16-GB
8-GB
4-GB
(9)
Hard drives
2-TB, 5400-rpm, 7 mm
2-TB, 5400-rpm, hybrid SSD, 7 mm
1-TB, 7200-rpm, 9.5 mm
1-TB, 5400-rpm, hybrid SSD, 9.5 mm
500 GB, 7200 rpm, 7 mm
500-GB, 5400-rpm, FIPS, 7 mm
500-GB, 5400-rpm, hybrid SSD, 7 mm
Solid-state drives, 2.5-inch, SATA-3, TLC
512-GB, FIPS-140-2
512-GB, OPAL 2, self-encrypting drive (SED)
512-GB
256-GB, FIPS-140-2
256-GB, OPAL 2, self-encrypting drive (SED)
256-GB
(10)
Hard drive cage
(11)
Hard drive cable
(12)
WLAN modules
Intel 7265 802.11AC 2x2 with Bluetooth M.2 Combo Card (non-vPro)
Intel Dual Band Wireless-AC 9560 802.11 AC 2x2 WiFi + Bluetooth 5.0 Combo Adapter (vPro)
Intel Dual Band Wireless-AC 9560 802.11 AC 2x2 WiFi + Bluetooth 5.0 Combo Adapter (non-vPro)
(13)
RTC battery
(14)
Fan
(15)
Heat sink (includes replacement thermal material)
65 W
35 W
(16)
Graphics processor with heat sink, AMD Radeon RX560 4GB GDDR5 (includes replacement thermal material)
(17)
Processor (include replacement thermal material)
Intel Core i7-8700T
Intel Core i7-8700K
Intel Core i7-8700
Intel Core i5-8600T
Intel Core i5-8600K
Intel Core i5-8600
Intel Core i5-8500T
Intel Core i5-8500
Intel Core i3-8300T
Intel Core i3-8100T
Intel Core i3-8033
Intel Core i3-8011
Intel Pentium G5600
Intel Pentium G5500
Intel Pentium G5500T
Intel Pentium G5400
Intel Pentium G5400T
Intel Celeron G4900
Intel Celeron G4900T
(18)
System board (includes replacement thermal material)
For use in models with 95W processors
For use in models with 65W processors
For use in models with 35W processors
(19)
Antenna cable, wireless
(20)
Stand
Miscellaneous parts
AC adapter
150 W, APFC
90 W, APFC
65 W, nPFC
EPS bracket
Dual VESA sleeve
Display cable, DVI
HP USB-Type C to USB Type-A Hub
Adapters
USB Type-C to USB 3.0
USB-C to DisplayPort
DisplayPort to DVI
USB to serial port
DisplayPort To HDMI 2.0
Keyboard
Washable, PVC, USB/PS2
USB
USB, Essential
Conferencing, USB
USB, slim
Wireless keyboard and mouse
Slim, PCR, USB (Brazil and Latin America)
Smart card, slim, CCID, USB
Anti-microbial, slim
Grey, slim, USB
Collaboration, USB
Collaboration, wireless
Wireless, premium
Health care, wired, USB
Premium, wireless, keyboard and mouse
Mouse
USB, optical
USB, laser
USB, premium
USB, antimicrobial
USB, hardened
USB, heath care, wired
Power cord
