    Fix HP Printer issue on macOS
HP ProDesk 400 G4 Desktop Mini Business PC - Components
Standard configuration features
Features may vary depending on the model. For a complete listing of the hardware and software installed in the computer, run the diagnostic utility (included on some computer models only).
This computer model can be used in a tower orientation or a desktop orientation. The tower stand is sold separately.
Front panel components
Figure : Front panel components
Your computer model may look slightly different from the illustration in this section.
Item
Icon
Component
Item
Icon
Component
1
USB 3.1 Gen 1 port*
4
Audio-out (headphone)/Audio-in (microphone) combo jack
2
USB 3.1 Gen 1 charging port
5
Main storage LED
3
Headphone jack
6
Dual-state power button
*Upgradeable to USB 3.1 Gen 2 port (10 Gbits/s data speed) in select configurations
The main storage LED is normally white when the power is on. If it is flashing red, there is a problem with the computer and the main storage LED is displaying a diagnostic code. Refer to Interpreting system validation diagnostic front panel LEDs and audible codes to interpret the code.
Rear panel components
Figure : Rear panel components
Item
Icon
Component
Item
Icon
Component
1
Antenna cover
7
Dual-Mode DisplayPort (2)
2
Thumbscrew
8
USB 3.1 Gen 1 ports (2)
3
USB 3.1 Gen 1 port
9
Optional port
One of the following ports may be used: DisplayPort, HDMI, VGA, USB Type-C, or serial port
4
Security cable slot
10
USB 2.0 port
5
External antenna connector (optional)
11
RJ-45 (network) jack/status lights
6
Padlock loop
12
Power connector
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available for use when contacting support for assistance.
Figure : Viewing the serial number location on the bottom of the computer
