    We are upgrading our website
    Fix Windows 10 Update Issues
HP ZHAN 66 Pro 15 G3 Notebook PC - Illustrated Parts
Computer major components
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Details about your computer, including model, serial number, product key, and length of warranty, are on the service tag at the bottom of your computer. See Labels for details.
Figure : Identifying the computer major components
Computer major components and their descriptions
Item
Spare part number
(1)
Display panel assembly
Display panels are only available as spare parts at the subcomponent level.
(2)
Top cover/keyboard (includes cable)
Backlight
L57504-001
No backlight
L57505-001
(3)
Touchpad
The touchpad cable is available in the Cable Kit as spare part number L45087-001.
L77267-001
(4)
Fingerprint sensor assembly
The fingerprint sensor cable is available in the Cable Kit as spare part number L45087-001.
L77268-001
(5)
System board (includes integrated processor and replacement thermal material)
All system boards use the following part numbers:
xxxxxx-001: Non-Windows operating system
xxxxxx-601: Windows 10 operating system
Intel Core i7-10510U processor and 2 GB of discrete graphics memory
L77251-xxx
Intel Core i5-10210U processor and 2 GB of discrete graphics memory
L77250-xxx
(6)
Heat sink (includes replacement thermal material)
L57506-001
(7)
Fan
L45101-001
(8)
RTC battery
L02772-001
(9)
USB board (includes cable)
The USB board cable is also available in the Cable Kit as spare part number L45087-001.
L44578-001
(10)
WLAN module
Intel Dual Band Wireless-AC 9560 802.11ac 2 × 2 Wi-Fi + Bluetooth 5.0 Combo Adaptor (non-vPro)
L22634-002
Intel Wi-Fi 6 AX201 802.11ax 2 × 2 + Bluetooth 5.0 (non-vPro)
L57250-002
(11)
Memory modules (DDR4-2666)
16 GB
937438-852
8 GB
937236-852
Memory modules (DDR4-3200)
16 GB
L67710-002
8 GB
L46598-002
(12)
Card reader board (includes cable)
The card reader board cable is also available in the Cable Kit as spare part number L45087-001.
L44579-001
(13)
Battery connector board
L45086-001
(14)
M.2 solid-state drive
512 GB, PCIe, TLC
L79593-001
512 GB, PCIe, value
L79594-001
512 GB PCIe + 32 GB Optane memory
L80981-001
256 GB, PCIe, TLC
L79591-001
256 GB, PCIe, value
L79592-001
256 GB PCIe + 16 GB Optane memory
L80980-001
128 GB, SATA-3, TLC
L79590-001
(15)
Thermal bracket (included in Bracket Kit)
L77275-001
(16)
Speaker assembly
L45092-001
(17)
Power connector cable
L01048-001
(18)
Battery
L32656-002
(19)
1 TB, 5400 rpm, 7 mm
832077-002
(20)
Bottom cover
L77266-001
Display components
Figure : Identifying the display components
Display components and their descriptions
Item
Spare part number
(1)
Display bezel (includes camera)
L79597-001
(2)
Camera module (includes bezel adhesive and display enclosure adhesive)
L83709-001
Microphone board (not illustrated)
L44541-001
(3)
Display panel (raw) (includes bezel adhesive and display enclosure adhesive)
FHD, 400 nits
L79596-001
FHD, 250 nits
L79595-001
(4)
Display/camera cable assembly (includes bezel adhesive and display enclosure adhesive)
L77270-001
(5)
WLAN antennas (includes bezel adhesive and display enclosure adhesive)
L77283-001
(6)
Hinge Kit (left and right) (includes bezel adhesive and display enclosure adhesive)
L79189-001
(7)
Display rear cover (includes wireless antennas and bezel adhesive)
L77277-001
Camera privacy cover (not illustrated)
L77237-001
Cable Kit
Figure : Identifying the Cable Kit components
Cable Kit components and their descriptions
Item
Spare part number
Cable Kit, includes the following parts:
L45087-001
(1)
USB board cable
(2)
Card reader board cable
(3)
Touchpad cable
(4)
Fingerprint sensor cable
Bracket Kit
Figure : Identifying the Bracket Kit components
Bracket Kit components and their descriptions
Item
Spare part number
Bracket Kit, includes the following parts:
L77275-001
(1)
Fingerprint sensor bracket
(2)
Thermal bracket
(3)
USB Type-C port bracket
(4)
RJ-45 (network) jack bracket
Mass storage devices
Figure : Identifying the mass storage devices
Mass storage devices and their descriptions
Item
Spare part number
(1)
Solid-state drive, M.2
512 GB, PCIe, TLC
L79593-001
512 GB, PCIe, value
L79594-001
L80981-001
256 GB, PCIe, TLC
L79591-001
256 GB, PCIe, value
L79592-001
L80980-001
128 GB, SATA-3, TLC
L79590-001
(2)
832077-002
Hard Drive Hardware Kit, includes the following parts:
L78776-001
(3)
Hard drive cover
(4)
Hard drive cable
Miscellaneous parts
Miscellaneous parts and their descriptions
Spare part number
AC adapters
65 W Smart AC power adapter, 4.5 mm barrel connector, S-3P, EM
913691-850
65 W, USB Type-C, wall mount, nPFC, 1.8 m (5.9 ft)
L32392-001
Plastics Kit (includes fingerprint sensor insert, conductive shielding tape, conductive touchpad tape, conductive bracket tape, and touchpad protective tape)
L77276-001
Screw Kit
L79191-001
Power cord (3-pin, C5, black, conventional, 1.0 m [3.3 ft]), for use in the People’s Republic of China
L19368-001
920688-014
Power cord (3-pin, C5NS, black, duckhead, 1.0 m [3.3 ft]), for use in the People’s Republic of China
L36823-001
Power cord (3-pin, C5NS, black, duckhead), for use in the People’s Republic of China
L50818-005
