    We are upgrading our website
    Fix Windows 10 Update Issues
HP ZHAN X 13 G2 Notebook PC - Components
Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
Right
Figure : Identifying the right-side components
Right-side components and their descriptions
Component
(1)
Security cable slot
Attaches an optional security cable to the computer.
The security cable is designed to act as a deterrent, but it may not prevent the computer from being mishandled or stolen.
(2)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
  warning:
To reduce the risk of personal injury, adjust the volume before putting on headphones, earbuds, or a headset. For additional safety information, refer to the Regulatory, Safety, and Environmental Notices.
To access this guide:
  1. Type HP Documentation in the taskbar search box, and then select HP Documentation.
When a device is connected to the jack, the computer speakers are disabled.
(3)
USB Type-C power connectors and Thunderbolt ports with HP Sleep and Charge (2)
Connect an AC adapter that has a USB Type-C connector, supplying power to the computer and, if needed, charging the computer battery.
– and –
Even when the computer is off, connect and charge most USB devices that have a Type-C connector, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
– and –
Connect a display device that has a USB Type-C connector, providing DisplayPort output.
The computer may also support a Thunderbolt docking station.
Cables and/or adapters (purchased separately may be required.
(4)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High Definition Multimedia Interface (HDMI) device.
(5)
USB SuperSpeed port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
(6)
Battery light
When AC power is connected:
  • White: The battery charge is greater than 90 percent.
  • Amber: The battery charge is from 0 to 90 percent.
  • Off: The battery is not charging.
When AC power is disconnected (battery not charging):
  • Blinking amber: The battery has reached a low battery level. When the battery has reached a critical battery level, the battery light begins blinking rapidly.
(7)
Power connector
Connects an AC adapter.
Left
Figure : Identifying the left-side components
Left-side components and their descriptions
Component
(1)
USB SuperSpeed port with HP Sleep and Charge
Connects a USB device, provides high-speed data transfer, and even when the computer is off, charges most products such as a cell phone, camera, activity tracker, or smartwatch.
(2)
Power button and power light
Power button:
  • When the computer is off, press the button to turn on the computer.
  • When the computer is on, press the button briefly to initiate Sleep.
  • When the computer is in the Sleep state, press the button briefly to exit Sleep (select products only).
  • When the computer is in Hibernation, press the button briefly to exit Hibernation.
Pressing and holding down the power button results in the loss of unsaved information.
If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options.
  1. Right-click the Power meter icon and then select Power Options.
Power light:
  • On: The computer is on.
  • Blinking: The computer is in the Sleep state, a power-saving state. The computer shuts off power to the display and other unneeded components.
  • Off: The computer is off or in Hibernation. Hibernation is a power-saving state that uses the least amount of power.
(3)
Vent
Enables airflow to cool internal components.
The computer fan starts up automatically to cool internal components and prevent overheating. It is normal for the internal fan to cycle on and off during routine operation.
(4)
Volume button
Controls speaker volume on the computer.
(5)
Smart card reader
Supports optional smart cards.
Refer to the illustration that most closely matches your computer.
Figure : Identifying the display components
Display components and their descriptions
Component
(1)
WLAN antennas* (select products only)
Send and receive wireless signals to communicate with WLANs.
(2)
Internal microphones
Record sound.
(3)
Camera(s)
Allow(s) you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
Camera functions vary depending on the camera hardware and software installed on your product.
(4)
Camera privacy switch
Turns the camera off and on.
(5)
Camera light(s)
On: One or more cameras are in use.
(6)
Ambient light sensor (select products only)
Adjusts the brightness of the display, depending on the ambient light.
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
Keyboard area
Touchpad
Figure : Identifying the Touchpad components
Touchpad components and their descriptions
Component
(1)
Touchpad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left touchpad button
Functions like the left button on an external mouse.
(3)
Right touchpad button
Functions like the right button on an external mouse.
Lights
Figure : Identifying the top lights
Lights and their descriptions
Component
(1)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(2)
Fn lock light
On: The fn key is locked.
(3)
Mute light
  • On: Computer sound is off.
  • Off: Computer sound is on.
(4)
Microphone mute light
  • On: Microphone is off.
  • Off: Microphone is on.
(5)
Num lk light
On: Num lock is on.
(6)
Wireless light
On: An integrated wireless device, such as a WLAN device and/or a Bluetooth® device, is on.
On some models, the wireless light is amber when all wireless devices are off.
(7)
Sharing or presenting light
On: Sharing is on.
(8)
Call answer light
On: Call answer is on.
(9)
Call end light
On: Call end is on.
Speakers and fingerprint sensor
Figure : Identifying the speakers and fingerprint sensor
Speakers and fingerprint sensor and their descriptions
Component
(1)
Speakers
Produce sound.
(2)
Fingerprint sensor (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
  1. To use the fingerprint sensor, place your finger on the fingerprint sensor until it reads your fingerprint.
    To prevent fingerprint logon issues, make sure when you register your fingerprint that all sides of your finger are registered by the fingerprint sensor.
Special keys
Figure : Identifying the special keys
Special keys and their descriptions
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes frequently used system functions when pressed in combination with another key. Such key combinations are called hot keys.
(3)
Windows key
Opens the Start menu.
Pressing the Windows key again will close the Start menu.
(4)
Action keys
Execute frequently used system functions.
(5)
Embedded numeric keypad
A numeric keypad superimposed over the keyboard alphabet keys. When fn+num lk is pressed, the keypad can be used like an external numeric keypad. Each key on the keypad performs the function indicated by the icon in the upper-right corner of the key.
If the keypad function is active when the computer is turned off, that function is reinstated when the computer is turned back on.
Bottom
Figure : Identifying the bottom components
Bottom components and their descriptions
Component
Vent
Top
Figure : Identifying the top components
Top components and their descriptions
Component
(1)
WLAN antennas
(2)
Record sound.
Labels
The labels affixed to the computer provide information you may need when you troubleshoot system problems or travel internationally with the computer. Labels may be in paper form or imprinted on the product.
Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
  • Service label—Provides important information to identify your computer. When contacting support, you may be asked for the serial number, the product number, or the model number. Locate this information before you contact support.
    Figure : Identifying the service label
    Component
    (1)
    HP product name
    (2)
    Model number
    (3)
    Product ID
    (4)
    Serial number
    (5)
    Warranty period
  • Regulatory label(s)—Provide(s) regulatory information about the computer.
  • Wireless certification label(s)—Provide(s) information about optional wireless devices and the approval markings for the countries or regions in which the devices have been approved for use.
