    Fix Windows 10 Update Issues
HP Z2 Tower G4 Workstation - Illustrated Parts
Computer major components
Figure : Identifying the major component components
Item
Component
(1)
Fan
(2)
3.5–inch hard drive
(3)
Drive cage
(4)
Access panel
(5)
Power supply
(6)
System board
(7)
USB Type-C module (select products only)
(8)
Front IO/User Interface (FIOUI) module
(9)
MicroSD memory card reader (select products only)
(10)
Chassis
(11)
Front bezel
System configuration specifications and differences can be found in the HP Z2 Tower G4 Workstation Quickspecs, located at http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=c05987463.
