    Fix Windows 10 Update Issues
HP Z2 Tower G4 Workstation - Components
Standard configuration features
Features may vary depending on the model.
Figure : HP Z2 Tower G4 Workstation
HP Z2 Tower G4 Workstations offer models with Intel® Xeon® E 21xx processors and Intel 8th-Gen Core-i™ series processors.
Models with Intel Core-i series processors support Windows 10 only.
Front
Figure : Identifying the front components
HP Z2 Tower G4 Workstation front panel components
1
5.25–inch hard disk/optical disc drive bays (2, optional)
5
MicroSD memory card reader (optional)
2
Power button
6
USB Type-C SuperSpeed Plus port with HP Sleep and Charge
3
Audio-out (headphone)/Audio-in (microphone) combo jack
7
USB SuperSpeed port with HP Sleep and Charge
4
USB SuperSpeed port
Rear
Figure : HP Z2 Tower G4 Workstation rear panel
HP Z2 Tower G4 Workstation rear panel components
1
Power cord connector
6
USB ports (2)
2
Audio line-in connector (blue)
7
USB SuperSpeed ports (4)
3
Audio line-out connector (green)
8
Expansion slots (optional, 4)
4
Display Port (DP) connectors (2)
9
Latches
5
RJ-45 (network) jack/status lights
The labels for the rear panel connectors use industry-standard icons and colors.
The DP and DVI-D ports are not supported when the system is configured with Intel Xeon E3-12x0 v5 processors. Also, if a discrete graphics card is installed these ports are disabled by default.
Simultaneous usage of integrated Intel HD graphics and discrete graphics cards (in order to drive more than two displays) can be enabled using the Computer (F10) Setup Utility. However, HP recommends using only discrete graphics cards when attaching three or more displays.
Left
Figure : Identifying the left components
Item
Component
Side access panel handle
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available when contacting support for assistance.
Figure : Identifying the computer serial number location
