    Fix Windows 10 Update Issues
HP Pavilion - 15-cs3045nl Product Specifications
8EW68EA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (1 x 16 GB)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
36.16 x 24.56 x 1.79 cm
1.94 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
B&O; Dual speakers; HP Audio Boost 1.0
Pre-installed software
Netflix
