    Fix Windows 10 Update Issues
HP Pavilion x360 - 15-dq0013nf Product Specifications
8PU16EA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 620
1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal HD SVA micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo;
35.9 x 24.16 x 2.07 cm
2.01 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 30 minutes
Video Playback Battery life
Up to 7 hours and 15 minutes
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix (30-day free trial offer)
