    Fix Windows 10 Update Issues
SUPPORT COMMUNICATION- SECURITY BULLETIN
Document ID: c06481941
Version: 1
HPSBHF03633 rev.1 - Intel Rapid Storage Technology (RSTe) Driver Installer Vulnerability
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Release date : 25-Oct-2019
Last updated : 05-Jun-2020
Potential Security Impact:
Escalation of privilege
Source: HP, HP Product Security Response Team (PSRT)
Reported by: Intel
VULNERABILITY SUMMARY
HP has been notified of a security vulnerability with the driver pack installers for Intel(R) RSTe package versions before version 4.7.0.2083 that may allow an authenticated user to escalate privilege via local access.
Reference Number
CVE-2018-12131, PSR-2019-0212
SUPPORTED SOFTWARE VERSIONS*: ONLY impacted versions are listed.
Driver pack installers for Intel(R) RSTe before version 4.7.0.2083
BACKGROUND
For a PGP signed version of this security bulletin please write to: hp-security-alert@hp.com
CVSS 3.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2018-12131
CVSS:3.0/AV:L/AC:H/PR:L/UI:R/S:C/C:L/I:L/A:L
5.0
RESOLUTION
The mitigated installer (Setup.exe) is version 4.7.0.1119 or newer. To verify the version of Setup.exe:
  1. Right-click Setup.exe.
  2. Select Properties, and then click the Details tab.
  3. Verify the file version is 4.7.0.1119 or greater.
Setup.exe version 4.7.0.1119 installs user interface version 4.7.0.2072 and driver version 4.7.0.1098. Only install Intel RSTe using Setup.exe version 4.7.0.1119 or greater.
HP recommends that any Setup.exe prior to version 4.7.0.1119 be removed from your system.
Below is the list of HP SoftPaqs with the Intel Setup.exe installer mitigated. These SoftPaqs install Intel RSTe user interface version 4.7.0.2072 and driver version 4.7.0.1098.
This bulletin might be updated when new information and/or SoftPaqs are available. Sign up for HP Subscriptions to be notified and receive:
  • Product support eAlerts
  • Driver updates
  • Security bulletin updates
HP recommends keeping your system up to date with the latest firmware and software.
Desktop Workstations
Product Name
Updated Version
SoftPaq#
SoftPaq Link
HP Z4 G4 Core-X Workstation Win 10
6.1.3.1006
SP99573
HP Z4 G4 Core-X Workstation Win 7
5.6.0.1006
SP99574
HP Z4 G4 Workstation (Xeon W) Win 10
6.1.3.1006
SP99573
HP Z4 G4 Workstation (Xeon W) Win 7
5.6.0.1006
SP99574
HP Z420 Workstation Win 10
4.3.0.1198
SP98397
HP Z420 Workstation Win 7-64
4.2.0.1136
SP98398
HP Z440 Workstation Win 10
4.7.0.2072
SP96420
HP Z440 Workstation Win 7
4.7.0.2072
SP96419
HP Z6 G4 Workstation Win 10
6.1.3.1006
SP99573
HP Z6 G4 Workstation Win 7
5.6.0.1006
SP99574
HP Z620 Workstation Win 10
4.3.0.1198
SP98397
HP Z620 Workstation Win 7-64
4.2.0.1136
SP98398
HP Z640 Workstation Win 10
4.7.0.2072
SP96420
HP Z640 Workstation Win 7
4.7.0.2072
SP96419
HP Z8 G4 Workstation Win 10
6.1.3.1006
SP99573
HP Z8 G4 Workstation Win 7
5.6.0.1006
SP99574
HP Z820 Workstation Win 10
4.3.0.1198
SP98397
HP Z820 Workstation Win 7-64
4.2.0.1136
SP98398
HP Z840 Workstation Win 10
4.7.0.2072
SP96420
HP Z840 Workstation Win 7
4.7.0.2072
SP96419
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit https://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://www.hp.com/go/alerts.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISION HISTORY : Version:1 - 25 October 2019 Initial Release
