    Fix Windows 10 Update Issues
HP Pavilion - 13-an1017tu Product Specifications
8PB41PA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 SDRAM (onboard)
Video graphics
Intel® UHD Graphics
Intel® Optane™ memory 32 GB + 512 GB QLC
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Intel® Wireless-AC 9461 Wi-Fi 5 (1x1) and Bluetooth® 5 Combo, non-vPro™
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4; 1 headphone/microphone combo;
31.1 x 21.1 x 1.54 cm
Starting at 1.3 kg
65 W EM AC power adapter
2-cell, 37.7 Wh Li-ion
HP Audio Switch; HP CoolSense; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings; HP BIOS Recovery
Pre-installed software
iQiyi; B&O Audio
