    Windows 11 Upgrade Guide
HP ENVY x360 - 15-dr1005tu Product Specifications
8PW84PA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
Intel® UHD Graphics
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit touch screen (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo
35.9 x 24.6 x 1.72 cm
2.05 kg
65 W AC power adapter
4-cell, 55.67 Wh Li-ion
BANG & OLUFSEN; Dual speakers; HP Audio Boost 2.0
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; iQiyi
