    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Fix Windows 10 Update Issues
OMEN X by HP 2S 15-dg0050ng Product Specifications
7GW65EA
Intel® Core™ i9-9880H (2.3 GHz base frequency, up to 4.8 GHz base with Intel® Turbo Boost Technology, 16 MB cache, 8 cores)
Microprocessor Cache
ERROR123
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Video graphics
ERROR123
Two 512 GB PCIe® NVMe™ TLC M.2 SSD with Raid 0 configured
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD 240 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080); 15.18 cm (5.98") diagonal FHD IPS BrightView micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
2 M.2 PCIe® x4
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin
36.21 x 26.17 x 2 cm
2.46 kg
230 W AC power adapter
6-cell, 72 Wh Li-ion polymer
Audio
ERROR123
B&O; dual speakers; HP Audio Boost; Omen Audio Control Support DTS:X® Ultra
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
