    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
Product Specifications for the HP Smart Tank Plus 570 Wireless All-in-One (5HX14A)
Product naming
Model name
5HX14A
What's included and accessories
What's in the box
HP Smart Tank Plus 570; 2 x HP GT53XL 135-ml Black Original Ink Bottle; HP GT52 Cyan Original Ink Bottle; HP GT52 Magenta Original Ink Bottle; HP GT52 Yellow Original Ink Bottle; Ink caution flyer; Repacking flyer; Setup guide; Reference guide; Regulatory flyer; PT flyer; RoH-EAC Regulatory flyer; Extended warranty flyer; Power cord; For more information about fill and yield, see http://www.hp.com/go/learnaboutsupplies
Connectivity
Ports
Hi-Speed USB 2.0, Dual Band Wi-Fi with Bluetooth LE
Wireless capability
Yes, built-in dual band Wi-Fi 802.11b/g/n, Wireless direct, BLE
Storage device and direct print support
Wireless direct printing
Copy
Copier settings
Number of Copies; Resize; Quality; Lighter/Darker; Papersize; Papertype; ID Copy; Collate; Enhancement
Color copy capability
Yes
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed, black (draft, A4)
Up to 22 cpm
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.4 B(A)
Acoustic pressure emissions
50 dB
Recommended operating humidity range
20 to 80% RH
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Storage temperature range (Celsius)
-40 to 60°C
Environmental specifications
No
Memory
Memory
256 MB; Integrated memory
Maximum Memory
256 MB
Mobile printing capability
Mobile printing services
HP Smart app; Apple AirPrint™; Fire™; Google Cloud Print 2.0; HP ePrint; Android printing; Mopria™-certified
Networking
Network protocols, supported
9100, SNMP, SLP, IPP, WS-Print, Wireless, LPR
Paper handling
Input capacity
Up to 100 sheets
Standard input capacity (cards)
Up to 30 cards
Standard input capacity (envelopes)
Up to 10
Output capacity
Up to 30 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope
Media sizes, custom (metric)
76.2 x 127 mm to 215.9 x 355.6 mm
Media types
Plain Paper, HP Photo Papers, HP Matte Brochure or Professional Paper, HP Matte Presentation Paper, HP Glossy Brochure or Professional Paper, other Photo Inkjet Papers, other Matte Inkjet Papers, other Glossy Inkjet Papers, Inkjet Hagaki, Plain Paper, Thick, HP Tri-fold Brochure Paper, Glossy, Light/Recycled
Media weight supported (metric)
Plain paper: 60 to 90 g/m²; Envelopes: 75 to 90 g/m²; Cards: up to 200 g/m²; Photo paper: up to 300 g/m²
Borderless printing
Yes (up to 8.5 x 11 in, 210 x 297 mm)
Paper handling - ADF
Automatic document feeder capacity
Standard, 35 sheets
Physical dimensions
Maximum dimensions (W x D x H, metric)
449 x 605.65 x 258.7 mm
Weight (metric)
6.19 kg
Power
Energy savings feature technology
HP Auto-Off Technology
Internal
Power supply
Input voltage : 200 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3Hz)
Power consumption
0.11 watts (manual-off), 3.72 watts (ready), 0.83 watts (sleep)
Print cartridges
Number of print cartridges
4 (1 each black bottle, set of 3 color bottles)
Replacement cartridges
HP GT53 90-ml Black Original Ink Bottle 1VV22AE; HP GT53XL 135-ml Black Original Ink Bottle 1VV21AE; HP GT52 Cyan Original Ink Bottle M0H54AE; HP GT52 Magenta Original Ink Bottle M0H55AE; HP GT52 Yellow Original Ink Bottle M0H56AE; HP GT51XL 135-ml Black Original Ink Bottle X4E40AE. For more information about fill and yield, see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed black (ISO)
Up to 11 ppm
Print speed color (ISO)
Up to 5 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi
Maximum print area (metric)
216 x 355 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Regulatory specifications
Safety
IEC 60950-1 & IEC 62368-1 compliant; Safety UL listed; EU LVD and EN 60950 & EN 62368 compliant; UL GS approved; Russia EAC
Electromagnetic compatibility
CISPR 32:2015/EN 55032:2015 Class B; CISPR24:2010/EN 55024:2010; EN 61000-3-2:2014; EN 61000-3-3:2013; ICES-003, 2016 Issue 6; EN 301 489-1 V2.1.1:2017; EAC (Russia)
Telecom compliance (fax capability)
EN 300 328 V2.1.1:2016; EN 301 893 V2.1.0:2018
Scan
Scan technology
Contact Image Sensor (CIS)
Scan speed (normal)
Up to 3 ppm (200 ppi, colour); Up to 5 ppm (200 ppi, monochrome)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Scanning options (ADF)
Single-sided
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum ADF scan size (metric)
216 x 356 mm
Twain version
Version 2.1
Security
Security management
No
System requirements
Minimum system requirements for Windows
Windows 10, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer 8.
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
OS X v10.11 El Capitan and above, Internet Access
Recommended Macintosh system requirements
Operating system (supported note)
Windows 10, 7; OS X v10.11 El Capitan; macOS Sierra v10.12 (previously OS X); macOS High Sierra v10.13; macOS Mojave v10.14
One year of 24/7 world-class technical support services through http://www.hp.com/support; One-year or 30,000 pages limited hardware warranty, whichever is earlier from the date of purchase; User replaceable parts have separate warranty periods
