    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Fix Windows 10 Update Issues
HP Gaming Pavilion - 15-dk0036nl Product Specifications
7KE49EA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 HDMI; 1 AC smart pin; 1 RJ-45; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
2.25 kg
150 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 9 hours
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
