    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion 15-cs1040ur Product Specifications
6AV35EA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
12 GB DDR4-2400 SDRAM (1 x 4 GB, 1 x 8 GB)
256 GB PCIe® NVMe™ M.2 SSD
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB Type-C™ 3.1 Gen 1 (Data transfer only, up to 5Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 1.4; 1 RJ-45; 1 headphone/microphone combo
36.16 x 24.16 x 1.79 cm
1.85 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 16 hours and 45 minutes
Video Playback Battery life
Up to 15 hours
FreeDOS 1.2
