    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion 15-bc510ns Product Specifications
6WR87EA
Intel® Core™ i7 9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
128 GB M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
38.24 x 25.25 x 2.45 cm
2.2 kg
150 W AC power adapter
4-cell, 63.3 Wh Li-ion polymer
Pre-installed software
Netflix
