    Fix Windows 10 Update Issues
    Are you working from home?
OMEN by HP - 15-dc0059np Product Specifications
7MY00EA
Intel® Core™ i5 8300H (2.3 GHz base frequency, up to 4 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ (5 Gb/s signaling rate, DisplayPort™ 1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 Mini DisplayPort™; 1 headphone/microphone combo; 1 microphone
36 x 26.3 x 2.5 cm
2.38 kg
135 W AC power adapter
4-cell, 70 Wh Li-ion
Battery life mixed usage
Up to 13 hours
Video Playback Battery life
Up to 8 hours and 15 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
OMEN Command Center; HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
