    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 14-dk0000np Product Specifications
6LF10EA
AMD A9-9425 Dual-Core (3.1 GHz base frequency, up to 3.7 GHz burst frequency, 1 MB cache)
AMD Integrated SoC
4 GB DDR4-1866 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ R5 Graphics
128 GB M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal HD SVA anti-glare micro-edge WLED-backlit (1366 x 768)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 3.1 Type-C™ (Data transfer only, 5 Gb/s signaling rate); 1 AC smart pin; 2 USB 3.1 Gen 1 Type-A (Data Transfer Only)
32.4 x 22.59 x 1.99 cm
1.47 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 8 hours
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
