HP Pavilion 15-cs2004nv Product Specifications
7DZ86EA
Intel® Core™ i7 8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2400 SDRAM (1 x 16 GB)
  • 128 GB M.2 SSD
  • 1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek RTL8821CE 802.11 b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
36.16 x 24.56 x 1.79 cm
1.94 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 7 hours and 15 minutes
