HP Pavilion 15-bc512tx Product Specifications
7PL71PA
Intel® Core™ i5-9300H (2.4 GHz base frequency, up to 4.1 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
38.24 x 25.25 x 2.45 cm
Starting at 2.09 kg
135 W AC power adapter
4-cell, 63.3 Wh Li-ion polymer
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows; HP BIOS Recovery
Pre-installed software
iQiyi
