    Apache Log4j Update
HP Spectre x360 - 15-df0013ng Product Specifications
6FB05EA
Intel® Core™ i7 8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2400 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal 4K IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass with Corning® Gorilla® Glass NBT™ (3840 x 2160)
1 microSD media card reader
2x USB Type-C™ Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1x USB 3.1 Gen 2 Type-A (HP Sleep and Charge); 1 HDMI; 1 headphone/microphone combo
36.1 x 25 x 1.93 cm
2.18 kg
135 W AC power adapter
6-cell, 84 Wh Li-ion
Battery life mixed usage
Up to 16 hours and 15 minutes
Video Playback Battery life
Up to 14 hours and 30 minutes
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP Connection Optimizer; HP JumpStart
Pre-installed software
Netflix
