HP ENVY X360 - 13-ar0007nf Product Specifications
7GY98EA
AMD Ryzen™ 7 3700U with Radeon™ Vega 10 Graphics (2.3 GHz base clock, up to 4 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
AMD Radeon™ RX Vega 10 Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
HP Sure View Integrated Privacy Screen 33.8 cm (13.3") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass with Corning® Gorilla® Glass NBT™ (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 microSD media card reader
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 headphone/microphone combo
30.6 x 21.2 x 1.47 cm
1.3 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Bang & Olufsen, quad speakers, HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
