Review hardware, software, and printer environment specifications.
- ${title}
- ${title}
- ${title}
- ${title}
HP LaserJet Managed MFP E52645 - Printer specifications
note:The following specifications are correct at the time of publication, but they are subject to change.
Technical specifications
Review the technical specifications for the printer.
Product numbers for each model
E52645dn - #1PS54A
Flow E52645c - #1PS55A
Paper handling features
E52645dn
Flow E52645c
Tray 1 (100-sheet capacity)
Tray 2 (550-sheet capacity)
Tray 3 (550-sheet capacity)
note: |
Optional
Optional
Convenience stapler
Not available
Automatic duplex printing
Connectivity features
E52645dn
Flow E52645c
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Hi-Speed USB 2.0
Print server for wireless network connectivity
Optional
Optional
Walk-up USB port
Hardware Integration Pocket for connecting accessory and third-party devices
HP Internal USB Ports
Optional
Optional
HP Jetdirect 3100w BLE/NFC/Wireless Accessory
Optional
Optional
HP Jetdirect 2900nw Print Server accessory for wireless connectivity
Optional
Optional
Wi-Fi Bluetooth Low Energy (BLE) Direct
Not available
Not available
Control-panel display and keyboard features
E52645dn
Flow E52645c
Color touchscreen control panel
Physical keyboard
Not available
Print features
E52645dn
Flow E52645c
Prints 45 pages per minute (ppm) on letter and 43 ppm on A4-size paper
USB printing
Mobile/cloud printing
Not available
Not available
Store jobs in the printer memory to print later or print privately
Copy and scan features
E52645dn
Flow E52645c
Copies 45 pages per minute (ppm) on letter and 40 ppm on A4-size paper
100-page document feeder with dual-head scanning for single-pass duplex copying and scanning
HP EveryPage Technologies including ultrasonic multi-feed detection
Not available
Embedded optical character recognition (OCR) provides the ability to convert printed pages into text that can be edited or searched using a computer
Not available
SMART Label feature provides paper-edge detection for automatic page cropping
Not available
Automatic page orientation for pages that have at least 100 characters of text
Not available
Automatic tone adjustment sets contrast, brightness, and background removal for each page
Not available
Digital Send features
E52645dn
Flow E52645c
Send documents to E-mail, USB, and shared folders on a network
Send documents to SharePoint®
Other features
E52645dn
Flow E52645c
1.75 GB base memory
note: |
16 GB embedded Multi-Media Controller (eMMC)
Not available
500 GB HP Secure High-Performance Hard Disk
Optional
HP Trusted Platform Module for encrypting all data that passes through the printer
Fax
Optional
Optional
Supported operating systems
Use the following information to ensure printer compatibility with your computer operating system.
Linux: For information and print drivers for Linux, go to www.hp.com/go/linuxprinting.
UNIX: For information and print drivers for UNIX®, go to www.hp.com/go/unixmodelscripts.
The following information applies to the printer-specific Windows HP PCL 6 print drivers, HP print drivers for macOS, and to the software installer.
Windows: Download HP Easy Start from 123.hp.com/LaserJet to install the HP print driver. Or, go to the printer-support website for this printer, http://www.hp.com/support/ljE52645mfp, to download the print driver or the software installer to install the HP print driver
macOS: Mac computers are supported with this printer. Download HP Easy Start either from 123.hp.com/LaserJet or from the Printer Support page, and then use HP Easy Start to install the HP print driver.
Go to 123.hp.com/LaserJet.
Follow the steps provided to download the printer software.
Print driver installed (for Windows, or the installer on the web for macOS)
Windows 7, 32-bit and 64-bit
The "HP PCL 6" printer-specific print driver is installed for this operating system as part of the software installation.
Windows 8, 32-bit and 64-bit
note: |
Windows 8.1, 32-bit and 64-bit
The "HP PCL-6" V4 printer-specific print driver is installed for this operating system as part of the software installation.
note: |
Windows 10, 32-bit and 64-bit
Windows Server 2008 R2, SP 1, 64-bit
The PCL 6 printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Windows Server 2012, 64-bit
Windows Server 2012 R2, 64-bit
Windows Server 2016, 64-bit
macOS 10.14 Mojave, 10.12 Sierra, macOS 10.13 High Sierra
Download HP Easy Start from 123.hp.com/LaserJet, and then use it to install the print driver.
note:Supported operating systems can change. For a current list of supported operating systems, go to http://www.hp.com/support/ljE52645mfp for HP's all-inclusive help for the printer.
note:For details on client and server operating systems and for HP UPD driver support for this printer, go to www.hp.com/go/upd. Under Additional information, click the links.
Windows
macOS
note:The Windows software installer installs the HP Smart Device Agent Base service. The file size is approximately 100 kb. Its only function is to check for printers connected via USB hourly. No data is collected. If a USB printer is found, it then tries to locate a JetAdvantage Management Connector (JAMc) instance on the network. If a JAMc is found, the HP Smart Device Agent Base is securely upgraded to a full Smart Device Agent from JAMc, which will then allow printed pages to be accounted for in a Managed Print Services (MPS) account. The driver-only web packs downloaded from hp.com for the printer and installed through the Add Printer wizard do not install this service.To uninstall the service, open the Windows Control Panel, select Programs or Programs and Features, and then select Add/Remove Programs or Uninstall a Program to remove the service. The file name is HPSmartDeviceAgentBase.
Printer dimensions
Make sure your printer environment is large enough to accommodate the printer.
note:These values are subject to change.
Dimension
Printer fully closed
Printer fully opened
Height
497 mm
750 mm
Depth
Tray 2 dust cover closed: 496 mm
Tray 2 dust cover open: 559 mm
674 mm
Width
482 mm
482 mm
Weight of the base printer: 23 kg
Dimension
Measurement
Height
130 mm
Depth
Tray closed: 376 mm
Tray opened: 569 mm
Width
410 mm
1.4 kg
Dimension
Measurement
Height
381 mm
Depth
Door closed: 632 mm
Door opened and rear castors rotated: 865 mm
Width
Door closed: 600 mm
Door opened and rear castors rotated: 630 mm
9.0 kg
Dimension
Height
1268 mm
1521 mm
Depth
632 mm
865 mm
Width
600 mm
630 mm
Weight of the printer with three 1 x 550-sheet paper feeders and stand: 36.2 kg
Power consumption
Review the power consumption for each printer status or function.
Printing
Ready
Sleep
Auto-Off
Off
629 W
28.8 W
5.28 W
0.06 W
0.06 W
Electrical specifications
Review the electrical specifications, including power requirements and rated current.
note:Power requirements are based on the country/region where the printer is sold. The values in the following tables are subject to change.
caution:Do not convert operating voltages. This can damage the printer and void the printer warranty.
Specification
110-volt models
220-volt models
Power requirements (Volts)1
100 to 127 volts (± 10%)
50/60 Hz (± 2 Hz)
220 to 240 volts (± 10%)
50/60 Hz (± 2 Hz)
Rated current (Amps)
7.5 Amps
4 Amps
1Power reported is highest value measured for all printer models using standard voltages.
Acoustic emissions
Review the acoustic emissions, including sound power level and sound pressure level.
Acoustics: Sound power level (pages per minute (ppm))
Declared per ISO 9296
Printing (43 ppm)
LwAD = 6.8 Bels (A)
Copying (43 ppm)
LwAD = 7.0 Bels (A)
Ready
LwAD = 4.0 Bels (A)
Acoustics: Sound pressure level (pages per minute (ppm))
Printing (43 ppm)
LpAm = 54 dB(A)
Copying (43 ppm)
LpAm = 56 dB(A)
Ready
LpAm = 25 dB(A)
Operating-environment range
Review the recommended operating-environment specifications for your printer.
Environment
Recommended
Allowed
Temperature
17° to 25°C
15° to 30°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
