HP LaserJet Enterprise MFP M528, HP LaserJet Managed MFP E52645 - 13.E1 jam error in the output bin
Use the following procedure to check for paper in all possible jam locations in the output bin. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.E1
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in the output bin:
  1. If paper is visible in the output bin, grasp the leading edge and remove it.
    Figure : Remove jammed paper from the output bin
